Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement
  1. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: step 1, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: step 1, image 2 of 2
    • This is an Oster Digital Electric Kettle
  2. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 1 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 2 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 3 of 3
    • Remove the three screws. They are tri-wing or triangular slotted screws. My set labeled them as number 4.
    • Once removed the plastic cover comes right off.
  3. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 1 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 2 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 3 of 3
    • The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip.
    • Remove the screw, a standard number 2 phillips head.
    • Slide the fiberglass sleeve down and off the fuse
  4. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: step 4, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: step 4, image 2 of 2
    • With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
  5. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: step 5, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: step 5, image 2 of 2
    • Testing the new fuse shows that electricity can flow through it.
    • I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
  6. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: step 6, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: step 6, image 2 of 2
    • Replace the fuse. The black band is down in this picture.
    • The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • So one must slowly open the band and then crimp it back on the new fuse.
    • I really have no good way of doing this, and it is the most time consuming and frustrating part of the whole repair. Take your time with a pick and pliers and slowly open them and replace the fuse.
  7. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: step 7, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: step 7, image 2 of 2
    • Now just slide the fiberglass sleeve back over the fuse.
    • Reattach the spring clip to hold the fuse on the heat element.
    • Make sure that the clip is directly over the fuse before tightening.
    • Replace the plastic cover and install the three tri-wing screws.
  8. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Try it out: step 8, image 1 of 1
    • Plug it back in and see if it heats water.
    Great, Scot! What an excellent tutorial! Thanks for making me a hero by following your clear instructions and great visuals. Done!
    lindsaycobb - Reply
22 other people completed this guide.
Scot Henderson
857 Reputation
2 Guides authored
8 Comments
Мне нравится этот чайник мне его подарили но проблема у нас электричество на 220 вольт. Вопрос как эго переделать на 220.
digital electronic kettle
Model: BVST-EK5967
120Vac 60HZ
vikangel - Reply
я не думаю, что это будет иметь значение для предохранителя. плавкий предохранитель рассчитан на 250 в, так что это может быть тот же предохранитель в 220 чайника.
я хотел бы посмотреть на предохранитель и посмотреть, если вы можете прочитать его. тогда просто заменить с тем же.
Scot Henderson - Reply
Where is fuse in Oster electric kettle BVSTKT5970
munu88 - Reply
this helped me 100 percent
joshua hofer - Reply
These steps worked fine for me. They are clear and concise. On Step 6, rather than trying to pry the crimp bands off, I cut them off and used new bands that came with the new fuse - much quicker.
Philip McCue - Reply
Hello,
I, on your recommendation, replaced the thermal switch and restored the operation of the kettle BVST-EK5967  . Thank you very much.
I ask you to step by step explain to me how to put in place the lid of the kettle.
Sincerely,
Sergey Petrosyan
Sergey Petrosyan - Reply
Excellent photos and instructions! My kettle is now good as new. The only difficulties were finding a trip-wing screwdriver bit (had to buy a set of security bits from Home Depot Pro) and then (as you said) prying off the old crimp bands. Wish I had new crimp bands to install instead…I'll go for those next time!
Mark Golembiewski - Reply
I tested the fuse and it tested good, so I tested the element by disconnecting the fuse end that had a removable plug and it had no continuity with ohm meter, unit no good as no way to replace heating element. I was at least able to know how to test unit, good instructions though.
James Stewart - Reply
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 102
All Time: 18,708
