Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement
  1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement, Top Panel Removal: step 1, image 1 of 1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 2, image 1 of 3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 2, image 2 of 3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 2, image 3 of 3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 3, image 1 of 2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 3, image 2 of 2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 4, image 1 of 2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: step 4, image 2 of 2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
Megan Saunders
701 Reputation
5 Guides authored
USF Tampa, Team S7-G5, Passmore Spring 2018 Member of USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 513
