Outer Shell Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Outer Shell Removal, Reposition the head strap: step 1, image 1 of 2 Outer Shell Removal, Reposition the head strap: step 1, image 2 of 2
    • Rotate the head strap forward as far as it will go.
  2. Outer Shell Removal, Unplug the All-In-One Cable: step 2, image 1 of 2 Outer Shell Removal, Unplug the All-In-One Cable: step 2, image 2 of 2
    • Unplug the All-In-One Cable from your headset.
  3. Outer Shell Removal, Remove the All-In-One Cable: step 3, image 1 of 3 Outer Shell Removal, Remove the All-In-One Cable: step 3, image 2 of 3 Outer Shell Removal, Remove the All-In-One Cable: step 3, image 3 of 3
    • Remove the All-In-One Cable from the cable guides along the left side of the head strap.
    • During reassembly, connect the All-In-One Cable to the headset before routing it through the cable guides. This will ensure it has the right amount of slack.
  4. Outer Shell Removal, Remove the top strap: step 4, image 1 of 2 Outer Shell Removal, Remove the top strap: step 4, image 2 of 2
    • Separate the top strap from itself where the Velcro secures it.
  5. Outer Shell Removal: step 5, image 1 of 3 Outer Shell Removal: step 5, image 2 of 3 Outer Shell Removal: step 5, image 3 of 3
    • Peel back the Velcro securing the rear of the top strap.
    • Feed the top strap out through the head strap to partially remove it.
  6. Outer Shell Removal: step 6, image 1 of 3 Outer Shell Removal: step 6, image 2 of 3 Outer Shell Removal: step 6, image 3 of 3
    • Feed the top strap through the clip near the front of headset to fully remove it.
  7. Outer Shell Removal, Remove the front side foam pads: step 7, image 1 of 3 Outer Shell Removal, Remove the front side foam pads: step 7, image 2 of 3 Outer Shell Removal, Remove the front side foam pads: step 7, image 3 of 3
    • Peel off both front side foam pads to uncover the speaker wires.
  8. Outer Shell Removal, Remove the two rubber spacers: step 8, image 1 of 3 Outer Shell Removal, Remove the two rubber spacers: step 8, image 2 of 3 Outer Shell Removal, Remove the two rubber spacers: step 8, image 3 of 3
    • Use the point of your spudger to pry out the two rubber spacers next to the headphone screws.
    • Be careful not to accidentally pry any of the speaker wires under the rubber spacer.
  9. Outer Shell Removal, Disconnect the speaker wires: step 9, image 1 of 3 Outer Shell Removal, Disconnect the speaker wires: step 9, image 2 of 3 Outer Shell Removal, Disconnect the speaker wires: step 9, image 3 of 3
    • Use the point of your spudger to pry up and disconnect both the left and right headphone speaker wires.
  10. Outer Shell Removal, Remove the head strap: step 10, image 1 of 2 Outer Shell Removal, Remove the head strap: step 10, image 2 of 2
    • Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
    • Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
    • Four 3.9 mm screws (two on each side)
    • Two 4.1 mm screws (one on each side)
  11. Outer Shell Removal: step 11, image 1 of 1
    • Remove the two plastic spacers underneath the previously removed Torx T6 screw.
  12. Outer Shell Removal: step 12, image 1 of 3 Outer Shell Removal: step 12, image 2 of 3 Outer Shell Removal: step 12, image 3 of 3
    • Thread the headphone speaker wires out through both ends of the head strap.
  13. Outer Shell Removal, Remove the outer shell: step 13, image 1 of 3 Outer Shell Removal, Remove the outer shell: step 13, image 2 of 3 Outer Shell Removal, Remove the outer shell: step 13, image 3 of 3
    • The four screws securing the outer shell are covered with black stickers. If the stickers are difficult to remove, simply press your T6 Torx driver through them.
  14. Outer Shell Removal: step 14, image 1 of 2 Outer Shell Removal: step 14, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 3.9 mm screws (two on top, two on bottom) securing the outer shell to the headset.
  15. Outer Shell Removal: step 15, image 1 of 3 Outer Shell Removal: step 15, image 2 of 3 Outer Shell Removal: step 15, image 3 of 3
    • Insert an opening pick into the seam between the two halves of the outer shell.
    • Slide the opening pick through the seam to dislodge the clips securing it to the headset.
    • Only insert the opening pick as far as necessary. There are ribbon cables underneath the outer shell.
  16. Outer Shell Removal: step 16, image 1 of 3 Outer Shell Removal: step 16, image 2 of 3 Outer Shell Removal: step 16, image 3 of 3
    • Continue sliding the opening pick through each seam until all clips have been dislodged.
  17. Outer Shell Removal: step 17, image 1 of 3 Outer Shell Removal: step 17, image 2 of 3 Outer Shell Removal: step 17, image 3 of 3
    • Carefully slide each half of the outer shell off of the sensor array.
    • Be careful not to snag any of the ribbon cables underneath.
Sam Omiotek
93,187 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 482
