P775DM3 Motherboard replacement
  1. P775DM3 Motherboard replacement, Battery: step 1, image 1 of 2 P775DM3 Motherboard replacement, Battery: step 1, image 2 of 2
    • Unlock the lock circled in red.
  2. P775DM3 Motherboard replacement: step 2, image 1 of 3 P775DM3 Motherboard replacement: step 2, image 2 of 3 P775DM3 Motherboard replacement: step 2, image 3 of 3
    • Lift the battery while unlocking the lock circled in red.
  3. P775DM3 Motherboard replacement, Disk access: step 3, image 1 of 1
    • Unscrew the two screws circled in red.
    • Slide the plate in the direction of the arrow.
  4. P775DM3 Motherboard replacement: step 4, image 1 of 2 P775DM3 Motherboard replacement: step 4, image 2 of 2
    • Lift the plate
  5. P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 1 of 3 P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 2 of 3 P775DM3 Motherboard replacement, Hard Disk Drive: step 5, image 3 of 3
    • Unscrew the screw circled in red.
    • Lift the disk with the green tab.
    • Remove the disk in the direction of the arrow.
  6. P775DM3 Motherboard replacement, M.2 SSD: step 6, image 1 of 2 P775DM3 Motherboard replacement, M.2 SSD: step 6, image 2 of 2
  7. P775DM3 Motherboard replacement: step 7, image 1 of 2 P775DM3 Motherboard replacement: step 7, image 2 of 2
    • Pull the SSD in the direction of the red arrow.
  8. P775DM3 Motherboard replacement, Access to major components: step 8, image 1 of 2 P775DM3 Motherboard replacement, Access to major components: step 8, image 2 of 2
    • Unscrew the five screws circled in red.
  9. P775DM3 Motherboard replacement: step 9, image 1 of 2 P775DM3 Motherboard replacement: step 9, image 2 of 2
    • Slide the plate in the direction of the red arrow.
  10. P775DM3 Motherboard replacement: step 10, image 1 of 2 P775DM3 Motherboard replacement: step 10, image 2 of 2
    • Lift the plate.
  11. P775DM3 Motherboard replacement, Keyboard: step 11, image 1 of 2 P775DM3 Motherboard replacement, Keyboard: step 11, image 2 of 2
  12. P775DM3 Motherboard replacement: step 12, image 1 of 3 P775DM3 Motherboard replacement: step 12, image 2 of 3 P775DM3 Motherboard replacement: step 12, image 3 of 3
    • Press a paper clip in the three places marked in red
    • Lift the keyboard and feel free to put some strength
  13. P775DM3 Motherboard replacement: step 13, image 1 of 2 P775DM3 Motherboard replacement: step 13, image 2 of 2
    • Disconnect the three framed connectors in red
  14. P775DM3 Motherboard replacement: step 14, image 1 of 2 P775DM3 Motherboard replacement: step 14, image 2 of 2
    • Pull the white drawer in the direction of the arrow to unlock the connector
    • Disconnect the red circled connector
  15. P775DM3 Motherboard replacement: step 15, image 1 of 2 P775DM3 Motherboard replacement: step 15, image 2 of 2
    • Pull the black drawer in the direction of the arrow to unlock the connector
  16. P775DM3 Motherboard replacement: step 16, image 1 of 3 P775DM3 Motherboard replacement: step 16, image 2 of 3 P775DM3 Motherboard replacement: step 16, image 3 of 3
    • Lift the flap that holds the connector circled in red
    • Remove the keyboard
  17. P775DM3 Motherboard replacement, RAM: step 17, image 1 of 3 P775DM3 Motherboard replacement, RAM: step 17, image 2 of 3 P775DM3 Motherboard replacement, RAM: step 17, image 3 of 3
    • Spread the two clips in red.
    • Remove the RAM card.
  18. P775DM3 Motherboard replacement, BIOS Battery: step 18, image 1 of 3 P775DM3 Motherboard replacement, BIOS Battery: step 18, image 2 of 3 P775DM3 Motherboard replacement, BIOS Battery: step 18, image 3 of 3
    • Disconnect the connector circled in red.
    • Remove the battery.
  19. P775DM3 Motherboard replacement, WLAN card removal: step 19, image 1 of 3 P775DM3 Motherboard replacement, WLAN card removal: step 19, image 2 of 3 P775DM3 Motherboard replacement, WLAN card removal: step 19, image 3 of 3
    • Disconnect the two connectors circled in green.
    • Remove the WLAN card.
  20. P775DM3 Motherboard replacement, Cooler: step 20, image 1 of 3 P775DM3 Motherboard replacement, Cooler: step 20, image 2 of 3 P775DM3 Motherboard replacement, Cooler: step 20, image 3 of 3
    • Unscrew the four large screws circled in green
    • Unscrew the five small screws circled in red
    • Lift the cooler with the two tabs circled in blue
  21. P775DM3 Motherboard replacement, CPU: step 21, image 1 of 3 P775DM3 Motherboard replacement, CPU: step 21, image 2 of 3 P775DM3 Motherboard replacement, CPU: step 21, image 3 of 3
    • Pull the lever circled in red in the direction of the red arrow while pressing on it.
    • Attention: Don't touch the underside of the processor, pick it up from the sides.
  22. P775DM3 Motherboard replacement, GPU: step 22, image 1 of 2 P775DM3 Motherboard replacement, GPU: step 22, image 2 of 2
  23. P775DM3 Motherboard replacement: step 23, image 1 of 3 P775DM3 Motherboard replacement: step 23, image 2 of 3 P775DM3 Motherboard replacement: step 23, image 3 of 3
    • Lift the card to allow access to the red circled connector
  24. P775DM3 Motherboard replacement: step 24, image 1 of 3 P775DM3 Motherboard replacement: step 24, image 2 of 3 P775DM3 Motherboard replacement: step 24, image 3 of 3
    • Pull it in the direction of the red arrow
  25. P775DM3 Motherboard replacement, Fans: step 25, image 1 of 3 P775DM3 Motherboard replacement, Fans: step 25, image 2 of 3 P775DM3 Motherboard replacement, Fans: step 25, image 3 of 3
    • Unscrew the three screws circled in red.
    • Disconnect the framed connector in red.
  26. P775DM3 Motherboard replacement: step 26, image 1 of 1
    • Remove the fan.
  27. P775DM3 Motherboard replacement: step 27, image 1 of 3 P775DM3 Motherboard replacement: step 27, image 2 of 3 P775DM3 Motherboard replacement: step 27, image 3 of 3
  28. P775DM3 Motherboard replacement: step 28, image 1 of 1
    • Lift the fan.
  29. P775DM3 Motherboard replacement, Motherboard: step 29, image 1 of 3 P775DM3 Motherboard replacement, Motherboard: step 29, image 2 of 3 P775DM3 Motherboard replacement, Motherboard: step 29, image 3 of 3
    • Lift the flap that holds the two connectors framed in red.
    • Disconnect the two framed connectors in red.
  30. P775DM3 Motherboard replacement: step 30, image 1 of 2 P775DM3 Motherboard replacement: step 30, image 2 of 2
    • Disconnect the box connector in green.
  31. P775DM3 Motherboard replacement: step 31, image 1 of 2 P775DM3 Motherboard replacement: step 31, image 2 of 2
    • Unscrew the twenty screws circled in red.
    • Unclip the edge of the case at the two places framed in green.
  32. P775DM3 Motherboard replacement: step 32, image 1 of 3 P775DM3 Motherboard replacement: step 32, image 2 of 3 P775DM3 Motherboard replacement: step 32, image 3 of 3
    • Remove the top of the case.
  33. P775DM3 Motherboard replacement: step 33, image 1 of 3 P775DM3 Motherboard replacement: step 33, image 2 of 3 P775DM3 Motherboard replacement: step 33, image 3 of 3
    • Remove the framed card in blue.
    • Remove the framed card in orange.
  34. P775DM3 Motherboard replacement: step 34, image 1 of 2 P775DM3 Motherboard replacement: step 34, image 2 of 2
    • Disconnect the two framed connectors in green.
  35. P775DM3 Motherboard replacement: step 35, image 1 of 2 P775DM3 Motherboard replacement: step 35, image 2 of 2
    • Disconnect the red circled connector.
  36. P775DM3 Motherboard replacement: step 36, image 1 of 2 P775DM3 Motherboard replacement: step 36, image 2 of 2
    • Remove the motherboard.
To reassemble your device, follow the instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 34
All Time: 2,235
