PDP Afterglow Wired Xbox 360 Controller Case Replacement
  1. PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: step 1, image 1 of 2 PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: step 1, image 2 of 2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Case Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Case Replacement: step 3, image 1 of 1
    • Remove the top cover from the bottom and place next to each other.
Aaron
103 Reputation
1 Guide authored
IUPUI, Team 3-1, Harley Fall 2015 Member of IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 15
All Time: 1,348
