PDP Rematch Advanced Back Shell Replacement
  1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 1 of 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 2 of 3 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: step 1, image 3 of 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Back Shell Replacement: step 2, image 1 of 3 PDP Rematch Advanced Back Shell Replacement: step 2, image 2 of 3 PDP Rematch Advanced Back Shell Replacement: step 2, image 3 of 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Back Shell Replacement: step 3, image 1 of 2 PDP Rematch Advanced Back Shell Replacement: step 3, image 2 of 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
  4. PDP Rematch Advanced Back Shell Replacement, Back Shell: step 4, image 1 of 2 PDP Rematch Advanced Back Shell Replacement, Back Shell: step 4, image 2 of 2
    • Grab the motor and pull away from the back shell. Repeat for both motors.
  5. PDP Rematch Advanced Back Shell Replacement: step 5, image 1 of 2 PDP Rematch Advanced Back Shell Replacement: step 5, image 2 of 2
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
  6. PDP Rematch Advanced Back Shell Replacement: step 6, image 1 of 3 PDP Rematch Advanced Back Shell Replacement: step 6, image 2 of 3 PDP Rematch Advanced Back Shell Replacement: step 6, image 3 of 3
    • Remove the motherboard from the back shell using moderate force.
Angel Velasquez
360 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 345
