PDP Rematch Advanced Front Housing Shell Replacement
  1. PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: step 1, image 1 of 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: step 1, image 2 of 3 PDP Rematch Advanced Front Housing Shell Replacement, Front Housing Shell: step 1, image 3 of 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Front Housing Shell Replacement: step 2, image 1 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 2, image 2 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 2, image 3 of 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Front Housing Shell Replacement: step 3, image 1 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 3, image 2 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 3, image 3 of 3
    • Peel the rubber piece off the back of the face buttons.
  4. PDP Rematch Advanced Front Housing Shell Replacement: step 4, image 1 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 4, image 2 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 4, image 3 of 3
    • Push all the face buttons out from the front of the shell.
  5. PDP Rematch Advanced Front Housing Shell Replacement: step 5, image 1 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 5, image 2 of 3 PDP Rematch Advanced Front Housing Shell Replacement: step 5, image 3 of 3
    • Put two fingers behind the bumpers and push upwards to remove them.
Collin Lawe
447 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 15
All Time: 289
