PDP Rematch Advanced Joystick Cover Replacement
  1. PDP Rematch Advanced Joystick Cover Replacement, Joystick Cover: step 1, image 1 of 3 PDP Rematch Advanced Joystick Cover Replacement, Joystick Cover: step 1, image 2 of 3 PDP Rematch Advanced Joystick Cover Replacement, Joystick Cover: step 1, image 3 of 3
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Joystick Cover Replacement: step 2, image 1 of 3 PDP Rematch Advanced Joystick Cover Replacement: step 2, image 2 of 3 PDP Rematch Advanced Joystick Cover Replacement: step 2, image 3 of 3
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Joystick Cover Replacement: step 3, image 1 of 2 PDP Rematch Advanced Joystick Cover Replacement: step 3, image 2 of 2
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
2 other people completed this guide.
Angel Velasquez
360 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 109
All Time: 1,543
