PDP Rematch Advanced Triggers Replacement
  1. PDP Rematch Advanced Triggers Replacement, Triggers: step 1, image 1 of 2 PDP Rematch Advanced Triggers Replacement, Triggers: step 1, image 2 of 2
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Triggers Replacement: step 2, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 2, image 2 of 2
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Triggers Replacement: step 3, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 3, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws that secure the motherboard.
  4. PDP Rematch Advanced Triggers Replacement: step 4, image 1 of 1
    • Remove the motherboard from the back shell using moderate force.
  5. PDP Rematch Advanced Triggers Replacement: step 5, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 5, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the two trigger springs from the motherboard.
  6. PDP Rematch Advanced Triggers Replacement: step 6, image 1 of 2 PDP Rematch Advanced Triggers Replacement: step 6, image 2 of 2
    • Use a hair dryer to remove the trigger from the motherboard.
Kevin Crawford
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 39
All Time: 354
