PDP Rematch Faceplate Replacement
  1. PDP Rematch Faceplate Replacement, Faceplate: step 1, image 1 of 2 PDP Rematch Faceplate Replacement, Faceplate: step 1, image 2 of 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Faceplate Replacement: step 2, image 1 of 2 PDP Rematch Faceplate Replacement: step 2, image 2 of 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Faceplate Replacement: step 3, image 1 of 2 PDP Rematch Faceplate Replacement: step 3, image 2 of 2
    • Gently lift off the hard cover with your hand; it should not need much force.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 28
All Time: 513
