PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement
  1. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement, Outer Casing: step 1, image 1 of 1
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
  2. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: step 2, image 1 of 1
    • Remove all seven 9 mm Phillips #000 screws securing the midframe.
    • Remove the midframe.
  3. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: step 3, image 1 of 2 PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: step 3, image 2 of 2
    • Optional: With a pair of tweezers, carefully wipe down the device.
    • It is recommended to use electrical disinfectant wipes or a microfiber towel to clean any excess debris.
After you have thoroughly cleaned the device, follow these steps in reverse order to reassemble the device.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 179
