PE254 Nose Pad Replacement
  1. PE254 Nose Pad Replacement, Nose Pad: step 1, image 1 of 1
    • Assess the eyewear for nose pad damage or cracks.
  2. PE254 Nose Pad Replacement: step 2, image 1 of 1
    • Place a 3-inch strip of tape on the lenses to protect them from being scratched.
  3. PE254 Nose Pad Replacement: step 3, image 1 of 1
    • Unscrew the nose pad screw using a Phillips-head screw driver. Turn the screw counter-clockwise until the screw can be removed
  4. PE254 Nose Pad Replacement: step 4, image 1 of 3 PE254 Nose Pad Replacement: step 4, image 2 of 3 PE254 Nose Pad Replacement: step 4, image 3 of 3
    • Remove the old nose pad and replace with a new one.
  5. PE254 Nose Pad Replacement: step 5, image 1 of 1
    • Place the screw back inside of the nose pad and turn clockwise until the screw is tight. Do not overtighten.
  6. PE254 Nose Pad Replacement: step 6, image 1 of 1
    • Repeat steps on the other side
    • Be careful when readjusting the pads.
Finish Line
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 18
Past 30 Days: 44
All Time: 2,668
