PENTAX OPTIO 330 Internal Battery replacement
  1. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: step 1, image 1 of 1
    • remove the two 2.5mm screw of the left side
  2. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: step 2, image 1 of 1
    • Remove two 4mm screw of the right side
  3. PENTAX OPTIO 330 Internal Battery replacement, Remove rear bloc: step 3, image 1 of 1
    • remove 2mm screw
    • remove 3mm screw
    • remove the three 3.5mm screw
  4. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: step 4, image 1 of 3 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: step 4, image 2 of 3 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: step 4, image 3 of 3
    • Open the memory protection
    • Remove gently the rear cover
    • When re-assembly take care to the thin tabs
  5. PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: step 5, image 1 of 2 PENTAX OPTIO 330 Internal Battery replacement, Remove rear cover: step 5, image 2 of 2
    • this part can fall down. So rome it before next step.
  6. PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: step 6, image 1 of 3 PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: step 6, image 2 of 3 PENTAX OPTIO 330 Internal Battery replacement, Front cover remove: step 6, image 3 of 3
    • Insérez ici votre traduction
  7. PENTAX OPTIO 330 Internal Battery replacement: step 7, image 1 of 1
    • Remove four screw
    • unplug the two Flex
  8. PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: step 8, image 1 of 2 PENTAX OPTIO 330 Internal Battery replacement, Battery replacement: step 8, image 2 of 2
    • This connector is directly to the board
    • This Flex connector need to be unplug
    • The 321 battery is there
    • You can add some thermal glue to fix the battery
    • I did it with a small piece of scotch
To re-assembly your device follow the step backward
Special thanks to these translators:
fr en
100%
Bertrand PIGEARD is helping us fix the world! Want to contribute?
Start translating ›
Bertrand PIGEARD
235 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 198
