PS Vita Slim Back Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. PS Vita Slim Back Panel Replacement, Back Panel: step 1, image 1 of 1
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Back Panel Replacement: step 2, image 1 of 2 PS Vita Slim Back Panel Replacement: step 2, image 2 of 2
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Back Panel Replacement: step 3, image 1 of 3 PS Vita Slim Back Panel Replacement: step 3, image 2 of 3 PS Vita Slim Back Panel Replacement: step 3, image 3 of 3
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Back Panel Replacement: step 4, image 1 of 1
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 227
