PS4 Case Opening Procedure
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. PS4 Case Opening Procedure, Flip over the PS4: step 1, image 1 of 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 1 of 3 PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 2 of 3 PS4 Case Opening Procedure, Remove the warranty stickers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PS4 Case Opening Procedure, Remove the plastic screw covers: step 3, image 1 of 2 PS4 Case Opening Procedure, Remove the plastic screw covers: step 3, image 2 of 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PS4 Case Opening Procedure, Remove the rear case screws: step 4, image 1 of 2 PS4 Case Opening Procedure, Remove the rear case screws: step 4, image 2 of 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PS4 Case Opening Procedure, Remove the lower case: step 5, image 1 of 2 PS4 Case Opening Procedure, Remove the lower case: step 5, image 2 of 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PS4 Case Opening Procedure: step 6, image 1 of 2 PS4 Case Opening Procedure: step 6, image 2 of 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
Sam Omiotek
93,256 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 494
