PS4 Hard Drive Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. PS4 Hard Drive Removal, Remove the hard drive cover: step 1, image 1 of 3 PS4 Hard Drive Removal, Remove the hard drive cover: step 1, image 2 of 3 PS4 Hard Drive Removal, Remove the hard drive cover: step 1, image 3 of 3
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. PS4 Hard Drive Removal, Remove the hard drive bracket screw: step 2, image 1 of 2 PS4 Hard Drive Removal, Remove the hard drive bracket screw: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. PS4 Hard Drive Removal, Remove the hard drive bracket: step 3, image 1 of 3 PS4 Hard Drive Removal, Remove the hard drive bracket: step 3, image 2 of 3 PS4 Hard Drive Removal, Remove the hard drive bracket: step 3, image 3 of 3
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
Sam Omiotek
93,409 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 216
