PS4 Optical Drive Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. PS4 Optical Drive Removal, Flip over the PS4: step 1, image 1 of 1
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PS4 Optical Drive Removal, Remove the warranty stickers: step 2, image 1 of 3 PS4 Optical Drive Removal, Remove the warranty stickers: step 2, image 2 of 3 PS4 Optical Drive Removal, Remove the warranty stickers: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PS4 Optical Drive Removal, Remove the plastic screw covers: step 3, image 1 of 2 PS4 Optical Drive Removal, Remove the plastic screw covers: step 3, image 2 of 2
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PS4 Optical Drive Removal, Remove the rear case screws: step 4, image 1 of 2 PS4 Optical Drive Removal, Remove the rear case screws: step 4, image 2 of 2
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PS4 Optical Drive Removal, Remove the lower case: step 5, image 1 of 2 PS4 Optical Drive Removal, Remove the lower case: step 5, image 2 of 2
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PS4 Optical Drive Removal: step 6, image 1 of 2 PS4 Optical Drive Removal: step 6, image 2 of 2
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PS4 Optical Drive Removal, Remove the Wi-Fi antenna: step 7, image 1 of 2 PS4 Optical Drive Removal, Remove the Wi-Fi antenna: step 7, image 2 of 2
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  8. PS4 Optical Drive Removal: step 8, image 1 of 3 PS4 Optical Drive Removal: step 8, image 2 of 3 PS4 Optical Drive Removal: step 8, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  9. PS4 Optical Drive Removal: step 9, image 1 of 3 PS4 Optical Drive Removal: step 9, image 2 of 3 PS4 Optical Drive Removal: step 9, image 3 of 3
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  10. PS4 Optical Drive Removal: step 10, image 1 of 2 PS4 Optical Drive Removal: step 10, image 2 of 2
    • Remove the 9.7 mm Torx security screw securing the antenna.
  11. PS4 Optical Drive Removal: step 11, image 1 of 2 PS4 Optical Drive Removal: step 11, image 2 of 2
    • Remove the Wi-Fi antenna.
  12. PS4 Optical Drive Removal, Disconnect the optical drive: step 12, image 1 of 3 PS4 Optical Drive Removal, Disconnect the optical drive: step 12, image 2 of 3 PS4 Optical Drive Removal, Disconnect the optical drive: step 12, image 3 of 3
    Buy
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
  13. PS4 Optical Drive Removal: step 13, image 1 of 3 PS4 Optical Drive Removal: step 13, image 2 of 3 PS4 Optical Drive Removal: step 13, image 3 of 3
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  14. PS4 Optical Drive Removal: step 14, image 1 of 2 PS4 Optical Drive Removal: step 14, image 2 of 2
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  15. PS4 Optical Drive Removal: step 15, image 1 of 3 PS4 Optical Drive Removal: step 15, image 2 of 3 PS4 Optical Drive Removal: step 15, image 3 of 3
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  16. PS4 Optical Drive Removal, Remove the optical drive: step 16, image 1 of 2 PS4 Optical Drive Removal, Remove the optical drive: step 16, image 2 of 2
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  17. PS4 Optical Drive Removal: step 17, image 1 of 2 PS4 Optical Drive Removal: step 17, image 2 of 2
    • Lift the optical drive straight up and out of the PS4.
Sam Omiotek
93,373 Reputation
290 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 277
