You're viewing a previously published version of this guide.  View latest version
Older Newer
PSP 2000 Front Casing Replacement
pepe32290
pepe32290 and 10 other contributors
Last updated on March 15, 2024
5 - 10 minutes
Easy
Introduction
Go to step 1
Paint job scratched? Going custom? Change out your faceplate assembly!
Parts
Tools
Show more…
  1. PSP 2000 Front Casing Replacement, Battery: step 1, image 1 of 3 PSP 2000 Front Casing Replacement, Battery: step 1, image 2 of 3 PSP 2000 Front Casing Replacement, Battery: step 1, image 3 of 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: step 2, image 1 of 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: step 3, image 1 of 2 PSP 2000 Front Casing Replacement: step 3, image 2 of 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: step 4, image 1 of 2 PSP 2000 Front Casing Replacement: step 4, image 2 of 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Front Casing Replacement: step 5, image 1 of 2 PSP 2000 Front Casing Replacement: step 5, image 2 of 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
pepe32290
1,668 Reputation
4 Guides authored
Cal Poly, Team 6-3, Maness Fall 2009 Member of Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Members
37 Guides authored
Past 24 Hours: 8
Past 7 Days: 81
Past 30 Days: 213
All Time: 28,372
