PSP 300x Power Jack Replacement
  1. PSP 300x Power Jack Replacement, Battery: step 1, image 1 of 3 PSP 300x Power Jack Replacement, Battery: step 1, image 2 of 3 PSP 300x Power Jack Replacement, Battery: step 1, image 3 of 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Power Jack Replacement, Front Casing: step 2, image 1 of 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Power Jack Replacement: step 3, image 1 of 2 PSP 300x Power Jack Replacement: step 3, image 2 of 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Power Jack Replacement: step 4, image 1 of 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Power Jack Replacement: step 5, image 1 of 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Power Jack Replacement: step 6, image 1 of 2 PSP 300x Power Jack Replacement: step 6, image 2 of 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
  7. PSP 300x Power Jack Replacement, LCD Screen: step 7, image 1 of 2 PSP 300x Power Jack Replacement, LCD Screen: step 7, image 2 of 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
  8. PSP 300x Power Jack Replacement: step 8, image 1 of 3 PSP 300x Power Jack Replacement: step 8, image 2 of 3 PSP 300x Power Jack Replacement: step 8, image 3 of 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
  9. PSP 300x Power Jack Replacement: step 9, image 1 of 2 PSP 300x Power Jack Replacement: step 9, image 2 of 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
  10. PSP 300x Power Jack Replacement: step 10, image 1 of 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x Power Jack Replacement, Power Jack: step 11, image 1 of 1
    • Flip up the lock and detach the ribbon cable above the power jack.
  12. PSP 300x Power Jack Replacement: step 12, image 1 of 1
    • Remove the screw from the power jack.
  13. PSP 300x Power Jack Replacement: step 13, image 1 of 1
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
  14. PSP 300x Power Jack Replacement: step 14, image 1 of 1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
8 other people completed this guide.
mbnewsom
3,430 Reputation
11 Guides authored
1 Guide Comment
Really easy to follow, thanks. You can dismiss the 10 and 11 steps being careful.
aONe - Reply
Past 24 Hours: 15
Past 7 Days: 75
Past 30 Days: 322
All Time: 25,354
