PSP E1000 Battery Replacement
  1. PSP E1000 Battery Replacement, Battery: step 1, image 1 of 2 PSP E1000 Battery Replacement, Battery: step 1, image 2 of 2
    • To start the replacement flip the device over
  2. PSP E1000 Battery Replacement: step 2, image 1 of 2 PSP E1000 Battery Replacement: step 2, image 2 of 2
    • We are going to start by removing the back panel.
    • To do this open the panel and gently squeeze in the UMD tray until it pops up.
    • It should lay flat against the back panel while open if done correctly
  3. PSP E1000 Battery Replacement: step 3, image 1 of 2 PSP E1000 Battery Replacement: step 3, image 2 of 2
    • Gently bend the back panel to free the hinge on the left.
    • Once it is popped out it should look like the second photo
    • The back panel can then be slid off
  4. PSP E1000 Battery Replacement: step 5, image 1 of 3 PSP E1000 Battery Replacement: step 5, image 2 of 3 PSP E1000 Battery Replacement: step 5, image 3 of 3
    • Remove the screw with a #00 Philips and slide up the battery cover.
    • The battery can now be removed by pulling it out.
    • When reinstalling, it is useful to use a spudger to push the cable back in.
    • Congratulations you have replaced your PSP E1000's battery
2 other people completed this guide.
Caleb Pierce
1,121 Reputation
8 Guides authored
1 Guide Comment
Past 24 Hours: 6
Past 7 Days: 75
Past 30 Days: 283
All Time: 2,540
