PSP E1000 UMD switch Replacement
Video Overview
  1. PSP E1000 UMD switch Replacement, UMD switch: step 1, image 1 of 3 PSP E1000 UMD switch Replacement, UMD switch: step 1, image 2 of 3 PSP E1000 UMD switch Replacement, UMD switch: step 1, image 3 of 3
    • If you haven't indication for inserted disk the problem probably is in UMD switch.
  2. PSP E1000 UMD switch Replacement: step 2, image 1 of 3 PSP E1000 UMD switch Replacement: step 2, image 2 of 3 PSP E1000 UMD switch Replacement: step 2, image 3 of 3
    • Unhook the door metal plate and disassemble UMD door.
  3. PSP E1000 UMD switch Replacement: step 3, image 1 of 2 PSP E1000 UMD switch Replacement: step 3, image 2 of 2
    • With a screwdriver I short the UMD switch to test the laser.
  4. PSP E1000 UMD switch Replacement: step 4, image 1 of 3 PSP E1000 UMD switch Replacement: step 4, image 2 of 3 PSP E1000 UMD switch Replacement: step 4, image 3 of 3
    • Now let's disassemble it.
  5. PSP E1000 UMD switch Replacement: step 5, image 1 of 3 PSP E1000 UMD switch Replacement: step 5, image 2 of 3 PSP E1000 UMD switch Replacement: step 5, image 3 of 3
    • Disconnect and remove the display.
  6. PSP E1000 UMD switch Replacement: step 6, image 1 of 2 PSP E1000 UMD switch Replacement: step 6, image 2 of 2
    • I must disconnect 7x cables and unscrew a screw.
  7. PSP E1000 UMD switch Replacement: step 7, image 1 of 3 PSP E1000 UMD switch Replacement: step 7, image 2 of 3 PSP E1000 UMD switch Replacement: step 7, image 3 of 3
    • Now I disconnect the battery connector and here is the mainboard.
  8. PSP E1000 UMD switch Replacement: step 8, image 1 of 2 PSP E1000 UMD switch Replacement: step 8, image 2 of 2
    • I used soldering station to remove the old one and put the new one (UMD switch).
  9. PSP E1000 UMD switch Replacement: step 9, image 1 of 3 PSP E1000 UMD switch Replacement: step 9, image 2 of 3 PSP E1000 UMD switch Replacement: step 9, image 3 of 3
    • Let's assemble and test it.
  10. PSP E1000 UMD switch Replacement: step 10, image 1 of 1
    • And it works!
5 other people completed this guide.
ZFix
194,093 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,699 Guides authored
One Comment
Step 2 - picture number 3 is wrong, I broke off a little part of my PSP E1004. The left arrow points up but you have to pull it down, while trying to pry gently to the right. I learned the hard way after I managed to take it off.
Dukefazon - Reply
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 132
All Time: 14,333
