Pac-Man Connect and Play Joystick Switchboard Replacement
  1. Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: step 1, image 1 of 2 Pac-Man Connect and Play Joystick Switchboard Replacement, Joystick Switchboard: step 1, image 2 of 2
    • Flip over the device
    • Ensure the device has no power and is not plugged into a TV
  2. Pac-Man Connect and Play Joystick Switchboard Replacement: step 2, image 1 of 1
    • Remove these 5 Phillips Head screws
  3. Pac-Man Connect and Play Joystick Switchboard Replacement: step 3, image 1 of 2 Pac-Man Connect and Play Joystick Switchboard Replacement: step 3, image 2 of 2
    • You can now open the device
  4. Pac-Man Connect and Play Joystick Switchboard Replacement: step 4, image 1 of 1
    • Remove these 2 screws (phillips)
  5. Pac-Man Connect and Play Joystick Switchboard Replacement: step 5, image 1 of 3 Pac-Man Connect and Play Joystick Switchboard Replacement: step 5, image 2 of 3 Pac-Man Connect and Play Joystick Switchboard Replacement: step 5, image 3 of 3
    • You can now remove the board
    • You can, at this time, also remove the plastic X that holds the joystick spring in place.
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 18
All Time: 566
