Pacific Image Electronics CS3600 Lens Replacement
  1. Pacific Image Electronics CS3600 Lens Replacement, Lens: step 1, image 1 of 2 Pacific Image Electronics CS3600 Lens Replacement, Lens: step 1, image 2 of 2
    • Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
  2. Pacific Image Electronics CS3600 Lens Replacement: step 2, image 1 of 1
    • Using light force open the device by pulling at the seam.
  3. Pacific Image Electronics CS3600 Lens Replacement: step 3, image 1 of 1
    • Use the J0 screwdriver to remove the screws that are 7 mm x 6 mm.
  4. Pacific Image Electronics CS3600 Lens Replacement: step 4, image 1 of 1
    • Once the screws are removed and casing removed the lens is revealed.
  5. Pacific Image Electronics CS3600 Lens Replacement: step 5, image 1 of 1
    • Simply remove the lens and replace accordingly!
Kristen Prince
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 227
