Pacific Image Electronics CS3600 Motor Replacement
  1. Pacific Image Electronics CS3600 Motor Replacement, Motor: step 1, image 1 of 2 Pacific Image Electronics CS3600 Motor Replacement, Motor: step 1, image 2 of 2
    • To start, open the device by removing the 5, 5mm x 9mm screws, with a Phillips J1 screwdriver.
  2. Pacific Image Electronics CS3600 Motor Replacement: step 2, image 1 of 1
    • Next, remove the 5 9mm x 5mm screws from the circled spots with a Phillips J1 screwdriver.
  3. Pacific Image Electronics CS3600 Motor Replacement: step 3, image 1 of 1
    • Once the screws are removed, carefully lift the motor casing out of the device.
    • The plastic piece circled acts as a clamp, lift the casing up and towards you to detach the casing.
  4. Pacific Image Electronics CS3600 Motor Replacement: step 4, image 1 of 2 Pacific Image Electronics CS3600 Motor Replacement: step 4, image 2 of 2
    • Now, with the motor casing in hand, remove the two 9mm x 5mm screw and washer at the top of the motor casing using a J1 screwdriver.
    • Gently pull the motor away from the casing to expose the wires.
  5. Pacific Image Electronics CS3600 Motor Replacement: step 5, image 1 of 1
    • Carefully desolder the wires from their contact point on the circuit board.
    • You have now successfully removed the motor!
Alessia Carlton
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 247
