Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: step 1, image 1 of 2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: step 1, image 2 of 2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: step 2, image 1 of 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: step 2, image 2 of 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: step 2, image 3 of 3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
5 other people completed this guide.
Jasmin
407 Reputation
1 Guide authored
iFixit EU Team Member of iFixit EU Team
Staff
44 Members
1,110 Guides authored
3 Comments
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - Reply
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - Reply
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 96
All Time: 7,531
