Paint Brush Ferrule Replacement
  1. Paint Brush Ferrule Replacement, Ferrule: step 1, image 1 of 1
    • Ensure the paint brush handle, bristles, and ferrule are completely dry. If so, proceed to step two.
    • If your brush is not dry, set in a warm dry location before proceeding to step two.
  2. Paint Brush Ferrule Replacement: step 2, image 1 of 1
    • Lightly sand the top of the paint brush handle and the inside of the ferrule.
    • Be sure to remove all excess glue, prepping for reattachment.
  3. Paint Brush Ferrule Replacement: step 3, image 1 of 1
    • Remove excess glue and sand particles from the paint brush and ferrule.
  4. Paint Brush Ferrule Replacement: step 4, image 1 of 1
    • Line the inside of the ferrule with heat resistant glue.
    • Be sure to line the ferrule with glue from the opening all the way to the end of the ferrule.
  5. Paint Brush Ferrule Replacement: step 5, image 1 of 1
    • Reattach the ferrule to the top of the paint brush handle.
    • After attached, if there is excess glue at the base of the ferrule remove it with a tissue.
  6. Paint Brush Ferrule Replacement: step 6, image 1 of 1
    • Allow the brush to dry for 48-72 hours before use.
Your paintbrush should dry in an upright position for 48-72 hours before use. Be sure to rinse out your paint brushes in lukewarm or cool water to avoid this problem again!
Hannah
160 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 2,051
