Palm Centro Screen Replacement
  1. Palm Centro Screen Replacement, Disassembling Palm Centro Battery: step 1, image 1 of 2 Palm Centro Screen Replacement, Disassembling Palm Centro Battery: step 1, image 2 of 2
    • Press and slide open the battery cover.
  2. Palm Centro Screen Replacement: step 2, image 1 of 1
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Palm Centro Screen Replacement: step 3, image 1 of 1
    • Phone with battery removed
  4. Palm Centro Screen Replacement, Back Housing: step 4, image 1 of 1
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Palm Centro Screen Replacement: step 5, image 1 of 1
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Palm Centro Screen Replacement: step 6, image 1 of 2 Palm Centro Screen Replacement: step 6, image 2 of 2
    • Remove the SIM card so housing can be separated.
  7. Palm Centro Screen Replacement: step 7, image 1 of 2 Palm Centro Screen Replacement: step 7, image 2 of 2
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Palm Centro Screen Replacement: step 8, image 1 of 2 Palm Centro Screen Replacement: step 8, image 2 of 2
    • Remove the small plastic insert at the bottom of the phone.
  9. Palm Centro Screen Replacement: step 9, image 1 of 2 Palm Centro Screen Replacement: step 9, image 2 of 2
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Palm Centro Screen Replacement, Logic Board: step 10, image 1 of 1
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Palm Centro Screen Replacement: step 11, image 1 of 1
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Palm Centro Screen Replacement: step 12, image 1 of 1
    • Separate the logic board from the case by lifting and pulling out the bottom.
  13. Palm Centro Screen Replacement, Screen: step 13, image 1 of 1
    • Slowly peel off the protective lining that is on the screen and keyboard.
  14. Palm Centro Screen Replacement: step 14, image 1 of 2 Palm Centro Screen Replacement: step 14, image 2 of 2
    • Lift and slowly remove the screen from the front panel
    • Place the new screen into the front panel
    • Make sure the new screen goes in under the plastic tabs for the additional memory slot door or it may not close properly once the phone is put back together.
3 other people completed this guide.
Tony
10 Reputation
1 Guide authored
Cal Poly, Team 15-49, Garner Spring 2010 Member of Cal Poly, Team 15-49, Garner Spring 2010
CPSU-GARNER-S10S15G49
5 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 2,946
