Palm IIIc Motherboard Replacement
  1. Palm IIIc Motherboard Replacement, Removing broken LCD screen: step 1, image 1 of 1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Motherboard Replacement: step 2, image 1 of 1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Motherboard Replacement, Remove the Front and Back Covers: step 3, image 1 of 1
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Screen-side down, unhook the battery cable from the motherboard.
  5. Palm IIIc Motherboard Replacement: step 5, image 1 of 2 Palm IIIc Motherboard Replacement: step 5, image 2 of 2
    • Unhook the blue and red screen cables.
  6. Palm IIIc Motherboard Replacement: step 6, image 1 of 2 Palm IIIc Motherboard Replacement: step 6, image 2 of 2
    • On the back of the motherboard near the top, gently lift up the flap that holds the ZIF connector tab in place. This will allow you to pull out the ZIF connector tab.
  7. Palm IIIc Motherboard Replacement: step 7, image 1 of 3 Palm IIIc Motherboard Replacement: step 7, image 2 of 3 Palm IIIc Motherboard Replacement: step 7, image 3 of 3
    • Located near the bottom of the motherboard will be two ZIF connector tabs. Gently lift up the flap that secures these tabs and remove the tabs.
  8. Palm IIIc Motherboard Replacement: step 8, image 1 of 1
    • Gently bend back the black clips that secure the motherboard.
    • Remove the motherboard starting from the left side and pull it out away from the clips.
Paulina Trujillo
265 Reputation
8 Guides authored
Cal Poly, Team 20-69, Walters Spring 2011 Member of Cal Poly, Team 20-69, Walters Spring 2011
CPSU-WALTERS-S11S20G69
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,167
