Palm IIIx Front Button Cluster Replacement
  1. Palm IIIx Front Button Cluster Replacement, Battery: step 1, image 1 of 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Front Button Cluster Replacement: step 2, image 1 of 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Front Button Cluster Replacement: step 3, image 1 of 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Front Button Cluster Replacement, Front Button Cluster: step 4, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Front Button Cluster Replacement: step 5, image 1 of 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers
  6. Palm IIIx Front Button Cluster Replacement: step 6, image 1 of 1
    • Hold the screen and front cover in a vertical position, facing the screen inward, as shown.
    • Position your hands so you can push the screen outward with your thumbs.
    • Remove the front cover by gently pushing outward with your thumbs. Use your index fingers to pull back on the front cover.
  7. Palm IIIx Front Button Cluster Replacement: step 7, image 1 of 1
    • Remove cluster by pulling on the rubber backing.
    • Clean, repair, and/or replace as neccessary.
David Haskell
44 Reputation
3 Guides authored
Cal Poly, Team 14-43, Regan Winter 2010 Member of Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,447
