Palm P101UNA Camera Screen Replacement
  1. Palm P101UNA Camera Screen Replacement, Battery: step 1, image 1 of 1
    • Push in the button at the bottom of the phone, and lift the back cap off.
  2. Palm P101UNA Camera Screen Replacement: step 2, image 1 of 1
    • Remove the battery by pulling out the little tab.
  3. Palm P101UNA Camera Screen Replacement, Camera Screen: step 3, image 1 of 1
    • Using the 1.5mm hex screwdriver, remove the 6 hex screws from the inner-most casing.
  4. Palm P101UNA Camera Screen Replacement: step 4, image 1 of 1
    • Using the spudger, remove the inner case from the phone.
  5. Palm P101UNA Camera Screen Replacement: step 5, image 1 of 1
    • Now place your finger on the outside of the screen and slowly apply pressure.
  6. Palm P101UNA Camera Screen Replacement: step 6, image 1 of 1
    Tool used on this step:
    Buy
    • While applying pressure, use your tweezers to remove the screen from the inner casing.
ironwill13791
509 Reputation
5 Guides authored
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013 Member of UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G2
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 360
