Palm Pre 2 Battery Replacement
  1. Palm Pre 2 Battery Replacement, Battery: step 1, image 1 of 2 Palm Pre 2 Battery Replacement, Battery: step 1, image 2 of 2
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Use a plastic opening tool to remove the rear cover. Slide the opening tool along the slit to release the plastic tabs.
  2. Palm Pre 2 Battery Replacement: step 2, image 1 of 3 Palm Pre 2 Battery Replacement: step 2, image 2 of 3 Palm Pre 2 Battery Replacement: step 2, image 3 of 3
    • Pull on the tab to remove the battery.
    • If the battery will not connect, insert a thin piece of cardboard between where the battery lies and the phone.
Elliott Van Hoy
256 Reputation
2 Guides authored
IUPUI, Team S1-G6, Freund Spring 2018 Member of IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 454
