Palm Pre 2 Keyboard Replacement
  1. Palm Pre 2 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Palm Pre 2 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Keyboard Replacement: step 2, image 1 of 2 Palm Pre 2 Keyboard Replacement: step 2, image 2 of 2
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Keyboard Replacement: step 3, image 1 of 2 Palm Pre 2 Keyboard Replacement: step 3, image 2 of 2
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Keyboard Replacement: step 4, image 1 of 2 Palm Pre 2 Keyboard Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas.
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Keyboard Replacement: step 5, image 1 of 2 Palm Pre 2 Keyboard Replacement: step 5, image 2 of 2
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Keyboard Replacement: step 6, image 1 of 3 Palm Pre 2 Keyboard Replacement: step 6, image 2 of 3 Palm Pre 2 Keyboard Replacement: step 6, image 3 of 3
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Keyboard Replacement: step 7, image 1 of 1
    • Use tweezers to separate the keyboard from the phone.
Elliott Van Hoy
256 Reputation
2 Guides authored
IUPUI, Team S1-G6, Freund Spring 2018 Member of IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 300
