Palm Pre Speaker Replacement
  1. Palm Pre Speaker Replacement, Battery: step 1, image 1 of 1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Speaker Replacement: step 2, image 1 of 1
    • Carefully pull up on the tab to remove the current battery.
  3. Palm Pre Speaker Replacement, Speaker: step 3, image 1 of 2 Palm Pre Speaker Replacement, Speaker: step 3, image 2 of 2
    • Use the t4 screwdriver to remove all 6 of the 3.6mm long screws.
  4. Palm Pre Speaker Replacement: step 4, image 1 of 2 Palm Pre Speaker Replacement: step 4, image 2 of 2
    • Use the spudger to locate the crease at the bottom of the keyboard.
    • Carefully work your way around the phone separating the back frame from the keyboard.
  5. Palm Pre Speaker Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the DIV and GPS antennas from the back of the keyboard.
  6. Palm Pre Speaker Replacement: step 6, image 1 of 1
    • Use the spuger to pry out the speaker. It is magnetically connected so do not be afraid to use the necessary force.
    • Make sure to take note of the orientation of the speaker for re-installation.
    • Make sure not the puncture the screen on the outside of the back frame.
noha
139 Reputation
6 Guides authored
Cal Poly, Team 7-31, Maness Spring 2012 Member of Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,175
