Palm Pre Volume Button Replacement
  1. Palm Pre Volume Button Replacement, Battery: step 1, image 1 of 1
    • Make sure your Palm Pre is turned off before disassembling the phone.
    • Snap off the back panel to reveal the battery.
  2. Palm Pre Volume Button Replacement: step 2, image 1 of 1
    • Carefully pull up on the tab to remove the current battery.
    • Locate the volume cavity on the right of the back frame.
    • Take your new volume button and slide in into the slot until the opposite end clicks.
    • You will have to use some force to do so.
noha
139 Reputation
6 Guides authored
Cal Poly, Team 7-31, Maness Spring 2012 Member of Cal Poly, Team 7-31, Maness Spring 2012
CPSU-MANESS-S12S7G31
3 Members
28 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 415
