Palm TX Motherboard Replacement
  1. Palm TX Motherboard Replacement, Back Panel: step 1, image 1 of 2 Palm TX Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Motherboard Replacement: step 2, image 1 of 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Motherboard Replacement: step 3, image 1 of 2 Palm TX Motherboard Replacement: step 3, image 2 of 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Motherboard Replacement: step 4, image 1 of 2 Palm TX Motherboard Replacement: step 4, image 2 of 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Motherboard Replacement: step 5, image 1 of 2 Palm TX Motherboard Replacement: step 5, image 2 of 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Motherboard Replacement, Battery Pack: step 6, image 1 of 2 Palm TX Motherboard Replacement, Battery Pack: step 6, image 2 of 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Motherboard Replacement, Motherboard: step 7, image 1 of 2 Palm TX Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Motherboard Replacement: step 8, image 1 of 2 Palm TX Motherboard Replacement: step 8, image 2 of 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
Spencer Lewson
793 Reputation
6 Guides authored
Cal Poly, Team 1-15, Amido Winter 2011 Member of Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Members
9 Guides authored
1 Guide Comment
Nicely done!
Matthew Newsom - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 3,804
