Palm Treo 600 Front Case Replacement
  1. Palm Treo 600 Front Case Replacement, Back Case: step 1, image 1 of 1
    • On the back of the device, locate the 3 rubber plugs, and use a plastic spudger to remove them.
  2. Palm Treo 600 Front Case Replacement: step 2, image 1 of 2 Palm Treo 600 Front Case Replacement: step 2, image 2 of 2
    • Use the T6 Torx Screwdriver to remove all 4 screws.
    • You have to first remove the Stylus to access the 4th screw.
  3. Palm Treo 600 Front Case Replacement: step 3, image 1 of 2 Palm Treo 600 Front Case Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, carefully separate the front and back cases.
    • Note: The antenna will detach from the phone.
  4. Palm Treo 600 Front Case Replacement, Front Case: step 4, image 1 of 2 Palm Treo 600 Front Case Replacement, Front Case: step 4, image 2 of 2
    • Using a T6 Torx Screwdriver, remove the two screws.
    • The motherboard will now be loose from the front case.
Michael Polka
22 Reputation
1 Guide authored
Cal Poly, Team 13-23, Maness Winter 2010 Member of Cal Poly, Team 13-23, Maness Winter 2010
CPSU-MANESS-W10S13G23
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,666
