Palm Treo 650 Keyboard Replacement
  1. Palm Treo 650 Keyboard Replacement, Battery and Stylus: step 1, image 1 of 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Keyboard Replacement: step 2, image 1 of 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Keyboard Replacement: step 3, image 1 of 2 Palm Treo 650 Keyboard Replacement: step 3, image 2 of 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Keyboard Replacement, Case: step 4, image 1 of 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Keyboard Replacement: step 5, image 1 of 2 Palm Treo 650 Keyboard Replacement: step 5, image 2 of 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Keyboard Replacement: step 6, image 1 of 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Keyboard Replacement: step 7, image 1 of 2 Palm Treo 650 Keyboard Replacement: step 7, image 2 of 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Keyboard Replacement, Motherboard: step 8, image 1 of 3 Palm Treo 650 Keyboard Replacement, Motherboard: step 8, image 2 of 3 Palm Treo 650 Keyboard Replacement, Motherboard: step 8, image 3 of 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Keyboard Replacement: step 9, image 1 of 2 Palm Treo 650 Keyboard Replacement: step 9, image 2 of 2
    • Pull off the motherboard.
  10. Palm Treo 650 Keyboard Replacement, Keyboard: step 10, image 1 of 1
    • Unscrew the two 3.2 mm screws with a Phillips #00 screwdriver.
  11. Palm Treo 650 Keyboard Replacement: step 11, image 1 of 1
    • Pull off the circuit board.
  12. Palm Treo 650 Keyboard Replacement: step 12, image 1 of 1
    • Remove the keypad for cleaning or replacing.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
cgood
134 Reputation
7 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 4,853
