Palm Treo 680 Back Panel Replacement
  1. Palm Treo 680 Back Panel Replacement, Battery: step 1, image 1 of 2 Palm Treo 680 Back Panel Replacement, Battery: step 1, image 2 of 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Back Panel Replacement: step 2, image 1 of 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Back Panel Replacement, Back Panel: step 3, image 1 of 2 Palm Treo 680 Back Panel Replacement, Back Panel: step 3, image 2 of 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Back Panel Replacement: step 4, image 1 of 2 Palm Treo 680 Back Panel Replacement: step 4, image 2 of 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Back Panel Replacement: step 5, image 1 of 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Back Panel Replacement: step 6, image 1 of 3 Palm Treo 680 Back Panel Replacement: step 6, image 2 of 3 Palm Treo 680 Back Panel Replacement: step 6, image 3 of 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
Maiya123
84 Reputation
6 Guides authored
Cal Poly, Team 6-4, Maness Fall 2009 Member of Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 7
All Time: 3,131
