Palm Treo 680 Motherboard Replacement
  1. Palm Treo 680 Motherboard Replacement, Battery: step 1, image 1 of 2 Palm Treo 680 Motherboard Replacement, Battery: step 1, image 2 of 2
    • Remove the battery cover by pressing on the small rectangular button located on the back of the phone.
  2. Palm Treo 680 Motherboard Replacement: step 2, image 1 of 1
    • Remove the battery by pulling it out towards you.
  3. Palm Treo 680 Motherboard Replacement, Back Panel: step 3, image 1 of 2 Palm Treo 680 Motherboard Replacement, Back Panel: step 3, image 2 of 2
    • Remove the stylus in order to access the screw.
    • Remove the 27mm top-left screw using a T6 Torx screwdriver.
  4. Palm Treo 680 Motherboard Replacement: step 4, image 1 of 2 Palm Treo 680 Motherboard Replacement: step 4, image 2 of 2
    • Using the spudger, remove the rubber rectangular cover located in the upper rear, right-hand corner.
    • Remove the 27mm screw using the T6 Torx screwdriver.
    • If there is a red Palm sticker covering this screw, puncture it to access the screw.
  5. Palm Treo 680 Motherboard Replacement: step 5, image 1 of 1
    • Remove the remaining two 27mm screws from the bottom using the T6 screwdriver.
  6. Palm Treo 680 Motherboard Replacement: step 6, image 1 of 3 Palm Treo 680 Motherboard Replacement: step 6, image 2 of 3 Palm Treo 680 Motherboard Replacement: step 6, image 3 of 3
    • Turn the phone so the screen is facing the right side.
    • Use a spudger to carefully separate the back panel from the front panel to access components inside the phone.
    • Separate the covers from the left side of the device as indicated in the picture.
    • The right side contains orange ribbons that are easily damaged.
  7. Palm Treo 680 Motherboard Replacement, Motherboard: step 7, image 1 of 2 Palm Treo 680 Motherboard Replacement, Motherboard: step 7, image 2 of 2
    • Slide the slim metal plate upwards until it disconnects from the motherboard.
    • DO NOT bend or crinkle this metal plate. It will be VERY DIFFICULT, IF NOT IMPOSSIBLE, to slide it back into place when you are re-assembling if you bend or crinkle this metal plate.
  8. Palm Treo 680 Motherboard Replacement: step 8, image 1 of 2 Palm Treo 680 Motherboard Replacement: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the orange ribbon that connects the screen to the motherboard.
    • Use tweezers to peel off the small piece of tape over the orange ribbon connector.
  9. Palm Treo 680 Motherboard Replacement: step 9, image 1 of 2 Palm Treo 680 Motherboard Replacement: step 9, image 2 of 2
    • Slide the spudger between the orange ribbon and black connector. Flip the black connector upwards to release the orange ribbon.
    • Using the spudger, pull the orange ribbon away from the connector to confirm the wire is fully disconnected.
  10. Palm Treo 680 Motherboard Replacement: step 10, image 1 of 3 Palm Treo 680 Motherboard Replacement: step 10, image 2 of 3 Palm Treo 680 Motherboard Replacement: step 10, image 3 of 3
    • Carefully turn the phone over so the screen is face up.
    • Locate the other orange ribbon that connects the motherboard to the faceplate.
    • Slide the spudger between the orange ribbon and tan connector. Lift the tan connector up to release the orange ribbon.
    • Separate the motherboard and faceplate of the Palm Treo.
2 other people completed this guide.
Maiya123
51 Reputation
6 Guides authored
Cal Poly, Team 6-4, Maness Fall 2009 Member of Cal Poly, Team 6-4, Maness Fall 2009
CPSU-MANESS-F09S6G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 3,359
