Palm Treo 700P Antenna Replacement
  1. Palm Treo 700P Antenna Replacement, Battery: step 1, image 1 of 3 Palm Treo 700P Antenna Replacement, Battery: step 1, image 2 of 3 Palm Treo 700P Antenna Replacement, Battery: step 1, image 3 of 3
    • Press the button located just above the Sprintâ„¢ logo and then slide the cover down.
  2. Palm Treo 700P Antenna Replacement: step 2, image 1 of 2 Palm Treo 700P Antenna Replacement: step 2, image 2 of 2
    • Use the small notch on the left hand side of the phone to remove the battery.
  3. Palm Treo 700P Antenna Replacement, Antenna: step 3, image 1 of 1
    • Remove the stylus from the phone.
  4. Palm Treo 700P Antenna Replacement: step 4, image 1 of 1
    • After removing the battery and stylus, unscrew the 5 Torx screws using a T-5 Torx screw driver.
  5. Palm Treo 700P Antenna Replacement: step 5, image 1 of 1
    • Using the spudger, remove the small rubberized patch under the antenna.
  6. Palm Treo 700P Antenna Replacement: step 6, image 1 of 1
    • Unscrew the last two screws using the same T-5 Torx screw driver.
  7. Palm Treo 700P Antenna Replacement: step 7, image 1 of 1
    • Using the plastic opening tool, carefully pry open the back case to loosen the antenna.
  8. Palm Treo 700P Antenna Replacement: step 8, image 1 of 1
    • The antenna will now be loose, gently pull the antenna out of the phone.
John Rainier Solanzo
7 Reputation
2 Guides authored
Cal Poly, Team 12-37, Regan Spring 2012 Member of Cal Poly, Team 12-37, Regan Spring 2012
CPSU-REGAN-S12S12G37
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 8
All Time: 794
