Palm m 100 Cover Replacement
  1. Palm m 100 Cover Replacement, Cover: step 1, image 1 of 1
    • Remove the batteries.
  2. Palm m 100 Cover Replacement: step 2, image 1 of 1
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Palm m 100 Cover Replacement: step 3, image 1 of 3 Palm m 100 Cover Replacement: step 3, image 2 of 3 Palm m 100 Cover Replacement: step 3, image 3 of 3
    • Remove rear cover by gently lifting it up from the bottom. To remove the front cover, flip the device over, and then separate the screen/circuit board from the cover.
  4. Palm m 100 Cover Replacement: step 4, image 1 of 1
    • Set aside broken cover, and replace with a new cover.
  5. Palm m 100 Cover Replacement: step 5, image 1 of 1
    • Close again like a book, and lay it gently into the front panel. Make sure the screen is facing outwards of the front panel.
  6. Palm m 100 Cover Replacement: step 6, image 1 of 1
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Anne Carey
1 Reputation
3 Guides authored
James Madison, Team 1-3, Allen Fall 2011 Member of James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 560
