Palm m105 Display Screen Replacement
  1. Palm m105 Display Screen Replacement, Display Screen: step 1, image 1 of 1
    • Flip the protective cover open and pull it straight away from the device to release the two clips.
  2. Palm m105 Display Screen Replacement: step 2, image 1 of 1
    • To remove the faceplate, locate the tab at the top of the device.
    • Lift the tab upwards with your finger.
    • The tab releases easily. Excessive force is not required.
  3. Palm m105 Display Screen Replacement: step 3, image 1 of 2 Palm m105 Display Screen Replacement: step 3, image 2 of 2
    Tool used on this step:
    T5 Torx Screwdriver
    $5.49
    Buy
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
    • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
  4. Palm m105 Display Screen Replacement: step 4, image 1 of 1
    • Be careful with this step. The motherboard and screen are attached by fragile cables.
    • Slowly lift the motherboard and the screen from the back case.
    • Gently hold the screen back so that you see the cables between it and the motherboard.
  5. Palm m105 Display Screen Replacement: step 5, image 1 of 2 Palm m105 Display Screen Replacement: step 5, image 2 of 2
    • Detach the screen from the motherboard by carefully pulling up on the three tabs.
    • Be careful. These tabs are fragile.
    • The motherboard and screen separate once the three tabs are released.
    • Recycle the old screen.
Erik Thompson
31 Reputation
5 Guides authored
UW Stout, Team 1-3, Zhou Fall 2011 Member of UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 868
