Palm m105 Motherboard Replacement
  1. Palm m105 Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Start with your intact Palm m105.
  2. Palm m105 Motherboard Replacement: step 2, image 1 of 1
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  3. Palm m105 Motherboard Replacement: step 3, image 1 of 1
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off
  4. Palm m105 Motherboard Replacement: step 4, image 1 of 2 Palm m105 Motherboard Replacement: step 4, image 2 of 2
    • Using a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  5. Palm m105 Motherboard Replacement: step 5, image 1 of 1
    • This is what the device looks like once you have taken the screws out and opened the device.
  6. Palm m105 Motherboard Replacement: step 6, image 1 of 1
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  7. Palm m105 Motherboard Replacement: step 7, image 1 of 1
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  8. Palm m105 Motherboard Replacement: step 8, image 1 of 1
Aaron
7 Reputation
1 Guide authored
UW Stout, Team 1-3, Zhou Fall 2011 Member of UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 1,088
