Palm m500 Battery Replacement
  1. Palm m500 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 Battery Replacement: step 2, image 1 of 2 Palm m500 Battery Replacement: step 2, image 2 of 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 Battery Replacement: step 3, image 1 of 3 Palm m500 Battery Replacement: step 3, image 2 of 3 Palm m500 Battery Replacement: step 3, image 3 of 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 Battery Replacement, Battery: step 4, image 1 of 3 Palm m500 Battery Replacement, Battery: step 4, image 2 of 3 Palm m500 Battery Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
6 other people completed this guide.
Brandan Williams
172 Reputation
1 Guide authored
Cal Poly, Team 14-9, Forte Winter 2011 Member of Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 11
Past 30 Days: 32
All Time: 5,672
