Palm m500 Motherboard Replacement
  1. Palm m500 Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
  2. Palm m500 Motherboard Replacement: step 2, image 1 of 2 Palm m500 Motherboard Replacement: step 2, image 2 of 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
  3. Palm m500 Motherboard Replacement: step 3, image 1 of 3 Palm m500 Motherboard Replacement: step 3, image 2 of 3 Palm m500 Motherboard Replacement: step 3, image 3 of 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
  4. Palm m500 Motherboard Replacement, Battery: step 4, image 1 of 3 Palm m500 Motherboard Replacement, Battery: step 4, image 2 of 3 Palm m500 Motherboard Replacement, Battery: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
  5. Palm m500 Motherboard Replacement, Motherboard: step 5, image 1 of 3 Palm m500 Motherboard Replacement, Motherboard: step 5, image 2 of 3 Palm m500 Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
Miles Johnson
579 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Winter 2011 Member of Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,169
