Panasonic ARC ES-LT3N Battery Replacement
  1. Panasonic ARC ES-LT3N Battery Replacement, Back Casing: step 1, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement, Back Casing: step 1, image 2 of 2
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Battery Replacement: step 2, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 2, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Battery Replacement: step 3, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 3, image 2 of 2
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Battery Replacement: step 4, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 4, image 2 of 2
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
  5. Panasonic ARC ES-LT3N Battery Replacement, Battery: step 5, image 1 of 1
    • Using the Phillips 00 driver bit, remove six screws (12mm) from the battery case.
  6. Panasonic ARC ES-LT3N Battery Replacement: step 6, image 1 of 1
    • Remove battery case.
  7. Panasonic ARC ES-LT3N Battery Replacement: step 7, image 1 of 2 Panasonic ARC ES-LT3N Battery Replacement: step 7, image 2 of 2
    • Remove old battery by lifting the battery up and left.
    • There are plastic brackets holding the battery on the right. Removing up and left ensures that the brackets will not be damaged and the battery will not come loose.
2 other people completed this guide.
Andrew Trainor
603 Reputation
5 Guides authored
One Comment
Where does one actually find the replacement batteries though?
WooKstah - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,701
