Panasonic ARC ES-LT3N Inner Blades Replacement
  1. Panasonic ARC ES-LT3N Inner Blades Replacement, Outer Foil: step 1, image 1 of 1
    • Remove the plastic cover
  2. Panasonic ARC ES-LT3N Inner Blades Replacement: step 2, image 1 of 3 Panasonic ARC ES-LT3N Inner Blades Replacement: step 2, image 2 of 3 Panasonic ARC ES-LT3N Inner Blades Replacement: step 2, image 3 of 3
    • Push the buttons on both sides of the razor head, this should release the foil
  3. Panasonic ARC ES-LT3N Inner Blades Replacement, Inner Blades: step 3, image 1 of 2 Panasonic ARC ES-LT3N Inner Blades Replacement, Inner Blades: step 3, image 2 of 2
    • Do not touch the top part of the blades, you may cut yourself
    • Pinch the sides of the inner blades and pull upward to remove
Andrew Trainor
603 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 503
