Panasonic CF-31 Toughbook Keyboard Replacement
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 1 of 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 2 of 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: step 1, image 3 of 3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 2, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 2, image 2 of 2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 3, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 3, image 2 of 2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 4, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 4, image 2 of 2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 5, image 1 of 1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 6, image 1 of 1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: step 7, image 1 of 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: step 7, image 2 of 2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 21
All Time: 3,083
