Panasonic Compact Shaver ES4815 Motor Replacement
  1. Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Battery: step 1, image 3 of 3
    • Twist the release cap to expose the batteries.
  2. Panasonic Compact Shaver ES4815 Motor Replacement: step 2, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 2, image 2 of 2
    • Remove the batteries.
  3. Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement, Motor: step 3, image 3 of 3
    • Remove the razor guard by pushing its release buttons and pulling.
  4. Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 4, image 3 of 3
    • Carefully pull out the inner blades.
  5. Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 5, image 3 of 3
    • Remove the two 1.9mm Phillips #0 screws from the inner blades.
  6. Panasonic Compact Shaver ES4815 Motor Replacement: step 6, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 6, image 2 of 2
    • Remove the metal plate.
  7. Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 1 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 2 of 3 Panasonic Compact Shaver ES4815 Motor Replacement: step 7, image 3 of 3
    • Pull the outer casing with one hand while holding the inner battery casing with the other hand.
  8. Panasonic Compact Shaver ES4815 Motor Replacement: step 8, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 8, image 2 of 2
    • Detach the white plastic blade base from the tip of the motor by pulling it.
  9. Panasonic Compact Shaver ES4815 Motor Replacement: step 9, image 1 of 2 Panasonic Compact Shaver ES4815 Motor Replacement: step 9, image 2 of 2
    • Detach motor from gray plastic holder by pulling it.
muhammad samsulsham
253 Reputation
2 Guides authored
IUPUI, Team S1-G5, Harley Spring 2018 Member of IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 537
