Panasonic D-snap SV-AV50 Screen Replacement
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: step 1, image 1 of 1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: step 2, image 1 of 1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: step 3, image 1 of 1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: step 5, image 1 of 1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: step 6, image 1 of 1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: step 7, image 1 of 1
    • Pull upwards on the screen border to remove it from the actual screen.
Zoe Hinck
29 Reputation
4 Guides authored
Cal Poly, Team 6-19, Amido Spring 2012 Member of Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 Members
12 Guides authored
One Comment
I need the LCD screen, can you helpme?
leon - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 12
All Time: 1,102
